[Ovmsdev] Car firmware v1.2.7
Fri Jun 8 08:41:08 HKT 2012
Tom,
Did you ever resolve this linker error? Someone else is also reporting the same now.
On 29 May, 2012, at 7:38 AM, Tom Saxton wrote:
> Also, I can't get the current sources to build. I get a linker error on all
> of the Roadster builds, it looks like the object code is too big to fit. See
> attached file.
> Do you have any idea what could be causing that? Are we using different
> versions of the compiler?
>    Tom
> <ovms-build-error.txt>
