[Ovmsdev] v2 Basic Hardware
Michael Stegen
michael at stegen.com
Thu Jul 5 05:04:41 HKT 2012
Looks very good!
If i'm not mistaken, Tesla used a similar extruded aluminium box for
some electronics module next to the VMS.
-Michael
Op 3-7-2012 2:43, Mark Webb-Johnson schreef:
> I thought you might be interested in seeing some early pictures of the
> prototypes for the vs basic hardware we've been working on with the
> China team.
> Some notes:
> * The design uses a metal rectangular "tube" style case, customised
> for us and cut to the width of our board. The case ends up about
> 7cm x 6cm. Labelled end-plates will go on, with cut-outs for the
> various connectors. The original design called for this to be
> black in colour, and we're still deciding on that (as the silver
> doesn't look bad and will be mostly covered with a black sticker
> anyway). Opening it involves removing the 4 screws on one side and
> sliding it out.
> * On one side we have the CAN (and power) DB9, GSM and GPS antennas.
> On the other side we have the DIAG DB9 and expansion bus connectors.
> * Holes for the LEDs are on the bottom of the case, and the LEDs
> themselves are on the bottom of the board, so that they are as
> close to the holes as possible.
> * There are zero internal cables, and only one circuit board
> containing the PIC controller and SIM908 modem - connection to the
> car is via the main CAN DB9, using custom cables. We have tried to
> follow ODBII standard pinouts for that connector.
> * For Tesla Roadster, we can use a custom 4 wire connector (Tesla
> DIAG port connector on one end, DB9 female on the other). For
> ODBII cars, a similar arrangement can be made.
> * The SIM908 modem chip supports GPS for those cars that don't have it.
> Still early days, but the design looks workable and should be much
> easier to assemble and QC than the v1 modules. Rock solid and
> (probably) bullet proof. It should also have good support for cars
> other than the Tesla Roadster.
> P.S. I'm also working on a more advanced hardware solution, as a
> personal project, that may end up being offered. Just experimenting at
> the moment. William is also working on some solutions for this based
> on *bone hardware and shields. These are much longer term, and
> we'll send out more details when we have some progress.
Stegen Electronics
Kwartslaan 95
3162 RD Rhoon
The Netherlands
Tel: +31 10-5016960
www.stegen.com
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20120704/a7fcecb6/attachment.htm>
Name: not available
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20120704/a7fcecb6/attachment-0006.png>
Name: not available
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20120704/a7fcecb6/attachment-0007.png>
Name: not available
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20120704/a7fcecb6/attachment-0008.png>
