[Ovmsdev] MAX942
Michael Stegen michael at stegen.com
Thu Jul 5 20:47:59 HKT 2012
Op 5-7-2012 2:27, Mark Webb-Johnson schreef:
> For the hardware guys - Michael Stegen, Brian, William - anyone :-)
> The MAX942 chip is used for the SIMCOM TX -> PIC RX line, to convert
> the 3.3v SIMCOM async communication to 5v TTL for the PIC.
> My understanding of this is that the SIMCOM chip, while expecting 3.3v
> can accept 5v (TX from PIC, RX to SIMCOM) - and a diode is used on the
> circuit for this.
Actually i used the internal pullup of the UART in the GSM modem (in my
original design) as a logic "1", the PIC will pull the line low when it
wants to send a logic "0". The diode also blocks any 5V from going into
the modem.
> But on the line from the SIMCOM to the PIC (TX from SIMCOM, RX to
> PIC), the SIMCOM only gives out 3.3v, but the PIC requires 5v TTL
> levels. One half of the MAX942 is used for that, and the other half is
> unused.
You can also power the PIC from 3.3v, i don't think that wil cause any
issues on the CAN transceiver.
The Can transceiver sees a logic "1" at 2 volts, so a level converter
between these two chips is not needed.
As the X-tal operates at 20Mhz, it should work. According to the
datasheet the max clock @ 3.3v is 25Mhz
Another way to make it a bit cheaper is to use a 18F26K80, an improved
version of the 18F2680. But that will likely require some changes to the
code, as it's not a direct replacement.
http://www.microchip.com/wwwproducts/Devices.aspx?dDocName=en550199
It also has two UARTS, and comperators, which you can use instead of the
MAX942.
-Michael
