[Ovmsdev] Strange preparing, connect-pwr-cable state
Sonny
email at sonnychen.com
Sun Feb 26 18:21:50 HKT 2012
Mark,
Great find.
I like the determine-by-charge-port-status method. Coincidentally, the
Android app has already been doing it that way.
Best regards,
Sonny
On Feb 25, 2012 10:51 PM, "Mark Webb-Johnson" <mark at webb-johnson.net> wrote:
> I think I now understand what is happening.
> The 0x95 message is the charge status for the current charge. For a normal
> charge in progress, that is fine. When the charge completes, the charge
> door is closed, and we are still ok. We still show the last charge status.
> Now, the opening of the charge door signals the car to start a new charge,
> and the old data is lost. Hence 'preparing to charge'. Even closing the
> charge door leaves the charge status as 'preparing to charge'. That was the
> last charge status.
> For the SMS STAT command, I think we're going to have to deal with this by
> if the car charge port is closed, then not showing any charge in progress
> (as opposed to the last charge status that we currently show).
> From the App point of view, if the charge port door is closed, then we
> also won't show any current charge status
> What we lose here is the status of the last charge, once the charge port
> is closed. But, perhaps that is the best way of doing things.
> Thoughts?
> On 25 Feb, 2012, at 11:51 AM, Mark Webb-Johnson wrote:
> I'm seeing something strange, that I'd like to know if it is repeatable
> for others. I previously thought this was some sequence problem with the
> messages we were sending (specifically, sending a start charge command when
> the charge port is closed or cable not plugged in), but I can now repeat it
> with just a normal idle car.
> Steps to reproduce:
> 1. Charge the car as normal, and wait for "Charge done".
> 2. Remove the charge plug+cable and close the charge port door.
> 3. SMS STAT the car and you should get "Standard - Charging done" as
> the status. All good.
> 4. Now, with the car still off, open the charge port door, wait a few
> seconds, then close it.
> 5. SMS STAT the car and now we seem to get "Standard - Charging,
> Preparing". A check on the can bus shows charge state 13, sub-state 7
> (preparing-to-charge, connect-pwr-cable). The iPhone App will show the
> battery with copper-coloured tops, as it seems to be expecting the car to
> be charging.
> This doesn't seem to happen with a car in 'stopped charge' state. The VDS
> shows nothing unusual (which implies that Tesla treat it specially, based
> on the charge door status).
> Can some other people try this, and let me know what you get? If you can
> have an App connected at the time of your test (so the server gets the
> logs), then let me know your vehicle ID, the time you did the test and what
> the result was, that would be helpful.
> It is not hard to handle as a special case in the code (both firmware and
> apps, or hacked in the firmware to detect the issue and put the state back
> to something more meaningful), but just seems a bit strange, as the state
> does not accurately reflect the car status.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20120226/b8aa5909/attachment.htm>
