[Ovmsdev] little problem/feature needed/debug
    Michael Stegen
    michael at stegen.com
    Sat Feb 18 06:01:57 HKT 2012
Sonny, Mark, others,
Thanks, the new update fixed the charge mode issues.
Some bugs:
I'm seeing the same two digit PIN limit now.
Also, setting the Charge current, causes a forced close of the app.
(might be related to the beta ICS version i have on my phone right now)
The app also shows SMS/Paranoid Mode Password.
Aren't those two different params? The app shows the SMS password "OVMS"
Somehow the notification mode setting is displayed as SMS only, instead
of "SMS, IP" I changed it in the app, rebooted the module, but it
doesn't stick. (at first i tought it did, but now it's back to "SMS" only)
Regards, Michael
Op 17-2-2012 17:16, William Petefish schreef:
> Hard reset performed. Module working again.
> Pin entry still limited to 2 characters.
> William
> On Feb 17, 2012 10:05 AM, "William Petefish"
> <william.petefish at gmail.com <mailto:william.petefish at gmail.com>> wrote:
>     Problem confirmed still. Module doesn't seem to be responding even
>     after the reboot request.
>     Another popped up, pin entry in app limited to 2 characters.
>     William
>     On Feb 17, 2012 8:34 AM, "William Petefish"
>     wrote:
>         Mark,
>         Will Do.
>         Waiting on it now.
>         I'll run a test after I get out of my first class.
>         William
>         On Fri, Feb 17, 2012 at 8:25 AM, Mark Webb-Johnson
>         <mark at webb-johnson.net <mailto:mark at webb-johnson.net>> wrote:
>             Michael,
>             I just tried from the iPhone App I'm working on, and all
>             seems ok.
>               * Car was not charging, standard mode with limit 13A on
>                 a 70A HPC.
>               * I sent a charge mode command to RANGE mode, and car
>                 switched to range mode, started charging at 13A and
>                 reported charging,range.
>               * I sent a charge mode command to STANDARD mode, and car
>                 switched to standard mode, while charge continued at
>                 13A and reported as charging,standard.
>               * I sent a charge limit command to 32A, then car sent
>                 back limit 32A and within a few seconds increased the
>                 current at the car to 32amp.
>               * I sent a charge limit command to 70A, then car sent
>                 back limit 70amp and within a few seconds increased
>                 the current at the car to 70amp.
>             Sonny says he has fixed the Android App charge mode and
>             the version in the market should be ok now. Can you try that?
>             If the new version has not yet been released, perhaps
>             selecting performance mode will enter range mode (assuming
>             3=2 and 4=3)?
>             Regards, Mark.
>             On 17 Feb, 2012, at 9:35 PM, Mark Webb-Johnson wrote:
>>             Michael,
>>             I tried issuing the commands manually on the can bus and
>>             can switch modes shown on the VDS.
>>             N.B. There is a bug in the Android App on the marketplace
>>             - it gets the mode numbers wrong (I guess 0..3 not 0,1,3,4).
>>             I'm implementing this in the iPhone App tonight, so
>>             should be able to test later.
>>             Regards, Mark.
>>             On 17 Feb, 2012, at 9:11 PM, Michael Stegen wrote:
>>>             I can confirm that switching between charge modes does
>>>             not work 100%.
>>>             I tried switching to range mode, and then start charging
>>>             from the app.
>>>             The battery indicator in the car changes, i.e. the top
>>>             of the battery is visible.
>>>             Range does not change, also charge mode visible on the
>>>             VDS does not change (still standard charging)
>>>             On the (Android) app , it's shows the same. After i
>>>             stopped the charging, i received a SMS that does not
>>>             start with Range - or Standard -
>>>             just "Charging Stopped, ideal range ..etc"
>>>             Tonight i'll try to send the commands manually on the
>>>             CAN bus, to see if i see any difference in behaviour.
>>>             Btw, i do receive a "Hello World" push message on my
>>>             android phone, but not on the Ipad.
>>>             I'm not using any testflight version anymore, but the
>>>             one from the appstore.
>>>             Btw2, when a charge is stopped, i used to receive a push
>>>             message + SMS, this somehow does not work anymore for
>>>             me. I only receive the SMS
>>>             Btw3, the car powers up fine, and starts charging, even
>>>             if left unused (but connected) for over a day.
>>>             -Michael
>>>             Op 17-2-2012 8:06, Mark Webb-Johnson schreef:
>>>>>             P.S. Could someone fix the display so it reads Range
>>>>>             Mode instead of Standard Mode when switched from
>>>>>             standard to range? (Much appreciated.)
>>>>             Is this Android App?
>>>>             If so, Sonny (again): modes are 0=standard,
>>>>             1=storage,3=range,4=performance
>>>>             P.S. What happened to mode 2? Did there used to be a
>>>>             mystery fifth mode?
>>>>             On 17 Feb 2012, at 2:59 PM, William Petefish wrote:
>>>>>             Mark,
>>>>>             Yes, fully repeatable, reproducible, and verifiable.
>>>>>             When not woken up first, none of the commands work.
>>>>>             I will restart the module and try further.
>>>>>             It will disarm the alarm and allow it to be driven.
>>>>>             William
>>>>>             On Fri, Feb 17, 2012 at 12:51 AM, Mark Webb-Johnson
>>>>>             wrote:
>>>>>                 William,
>>>>>                 Is it repeatable?
>>>>>                 ie; plug in, stop charge. wait 5 minutes until
>>>>>                 coolant pump turns off, then try start charge from
>>>>>                 the app.
>>>>>                 Also, are other commands working (like lock/unlock)?
>>>>>                 After setting the feature for write-enabled CAN
>>>>>                 bus, you need to restart the module. If not, none
>>>>>                 of the commands will work. If at least one of the
>>>>>                 commands is working, then that is fine.
>>>>>                 Regards, Mark.
>>>>>                 P.S. Not wishing to hijack this thread, but since
>>>>>                 you are in the USA - could you test the
>>>>>                 lock/unlock commands for us on your US car?
>>>>>                 Supposedly, the US cars don't have an immobiliser
>>>>>                 so that the UNLOCK command will disable the alarm
>>>>>                 and allow the car to be driven. Please try and let
>>>>>                 us know.
>>>>>                 On 17 Feb 2012, at 2:35 PM, William Petefish wrote:
>>>>>>                 Mark,
>>>>>>                 Yes, I did and to no avail. I had purposefully
>>>>>>                 let the car sit until it went into power save
>>>>>>                 mode and tried again, no joy.
>>>>>>                 Might it have something to do with the new FW on
>>>>>>                 the roadster? (4.6.4 I think is the FW that is on
>>>>>>                 mine.) My roadster is a 2.5.
>>>>>>                 William
>>>>>>                 On Fri, Feb 17, 2012 at 12:29 AM, Mark
>>>>>>                 Webb-Johnson <mark at webb-johnson.net
>>>>>>                     William:
>>>>>>                     Current (1.2.0-rc3) code is:
>>>>>>                         void can_tx_setchargecurrent(unsigned
>>>>>>                         char current)
>>>>>>                           while (TXB0CONbits.TXREQ) {} // Loop
>>>>>>                         until TX is done
>>>>>>                           TXB0CON = 0;
>>>>>>                           TXB0SIDL = 0b01000000; // Setup 0x102
>>>>>>                           TXB0SIDH = 0b00100000; // Setup 0x102
>>>>>>                           TXB0D0 = 0x05;
>>>>>>                           TXB0D1 = 0x02;
>>>>>>                           TXB0D2 = 0x00;
>>>>>>                           TXB0D3 = 0x00;
>>>>>>                           TXB0D4 = current;
>>>>>>                           TXB0D5 = 0x00;
>>>>>>                           TXB0D6 = 0x00;
>>>>>>                           TXB0D7 = 0x00;
>>>>>>                           TXB0DLC = 0b00001000; // data length (8)
>>>>>>                           TXB0CON = 0b00001000; // mark for
>>>>>>                         transmission
>>>>>>                         until TX is done
>>>>>>                           can_tx_wakeup(); // Also, wakeup the
>>>>>>                         car if necessary
>>>>>>                         void can_tx_wakeup(void)
>>>>>>                         until TX is done
>>>>>>                           TXB0CON = 0;
>>>>>>                           TXB0D0 = 0x0a;
>>>>>>                           TXB0DLC = 0b00000001; // data length (8)
>>>>>>                         transmission
>>>>>>                         until TX is done
>>>>>>                     That should work. Pre-rc3, I used to see
>>>>>>                     this, but since rc3 it has been ok for me.
>>>>>>                     Maybe the bus was busy and lost the wakeup
>>>>>>                     message? Did you try sending any other
>>>>>>                     commands, or repeating the start charge command?
>>>>>>                     What is the version of your car (2.x or 1.5?).
>>>>>>                     Regards, Mark.
>>>>>>                     P.S. There is also a specific command C,18
>>>>>>                     that calls the CAN wakeup function. Not sure
>>>>>>                     if the Android App supports it or not.
>>>>>>                     On 17 Feb 2012, at 2:22 PM, William Petefish
>>>>>>                     wrote:
>>>>>>>                     Mark,
>>>>>>>                     Feature Needed: Wake Up command.
>>>>>>>                     I tried to send the start charge command
>>>>>>>                     from my android phone and it wouldn't start
>>>>>>>                     to charge or change charging mode, etc.
>>>>>>>                     without being woken up by opening/closing
>>>>>>>                     the doors/trunk/remote/etc.
>>>>>>>                     I am using the latest release (1.20) and the
>>>>>>>                     Android app.
>>>>>>>                     William
>>>>>>                     _______________________________________________
>>>>>>                     OvmsDev mailing list
>>>>>>                     OvmsDev at lists.teslaclub.hk
>>>>>>                     <mailto:OvmsDev at lists.teslaclub.hk>
>>>>>>                     http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
>>>>             OvmsDev at lists.teslaclub.hk  <mailto:OvmsDev at lists.teslaclub.hk>
>>>             Stegen Electronics
>>>             Kwartslaan 95
>>>             3162 RD Rhoon
>>>             The Netherlands
>>>             Tel:+31 10-5016960  <tel:%2B31%2010-5016960>
>>>             www.stegen.com  <http://www.stegen.com/>
Stegen Electronics
Kwartslaan 95
3162 RD Rhoon
The Netherlands
Tel: +31 10-5016960
www.stegen.com
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20120217/dbdfd72d/attachment.htm>
