[Ovmsdev] little problem/feature needed/debug
Sat Feb 18 14:49:08 HKT 2012
Sonny,
This sounds cool. Could you post some screen-shots for us Android-deprived Apple fan-boys?
On 18 Feb, 2012, at 11:07 AM, Sonny <email at sonnychen.com> wrote:
> 3. A new 4x1 home screen widget has been added to the latest version. Please note that it will only show up in the add widgets list when the app is installed inside phone memory (not SD card). This seems to be an Android restriction.
> 4. The widget is highly experimental and will be improved over upcoming updates. The way the app works now is that it closes the server TCP connection when it goes to background. As such, the widget's data can refresh only when the main app is opened. While I want to keep the TCP shutdown behavior, in the next version, at least the parking meter will remain live all the time.
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20120218/a9da3f40/attachment.html>
