[Ovmsdev] little problem/feature needed/debug
William Petefish
william.petefish at gmail.com
Sat Feb 18 00:16:59 HKT 2012
Hard reset performed. Module working again.
Pin entry still limited to 2 characters.
William
On Feb 17, 2012 10:05 AM, "William Petefish" <william.petefish at gmail.com>
wrote:
> Problem confirmed still. Module doesn't seem to be responding even after
> the reboot request.
> Another popped up, pin entry in app limited to 2 characters.
> William
> On Feb 17, 2012 8:34 AM, "William Petefish" <william.petefish at gmail.com>
> wrote:
>> Mark,
>> Will Do.
>> Waiting on it now.
>> I'll run a test after I get out of my first class.
>> William
>> On Fri, Feb 17, 2012 at 8:25 AM, Mark Webb-Johnson <mark at webb-johnson.net
>> > wrote:
>>> Michael,
>>> I just tried from the iPhone App I'm working on, and all seems ok.
>>> - Car was not charging, standard mode with limit 13A on a 70A HPC.
>>> - I sent a charge mode command to RANGE mode, and car switched to
>>> range mode, started charging at 13A and reported charging,range.
>>> - I sent a charge mode command to STANDARD mode, and car switched to
>>> standard mode, while charge continued at 13A and reported as
>>> charging,standard.
>>> - I sent a charge limit command to 32A, then car sent back limit 32A
>>> and within a few seconds increased the current at the car to 32amp.
>>> - I sent a charge limit command to 70A, then car sent back limit
>>> 70amp and within a few seconds increased the current at the car to 70amp.
>>> Sonny says he has fixed the Android App charge mode and the version in
>>> the market should be ok now. Can you try that?
>>> If the new version has not yet been released, perhaps selecting
>>> performance mode will enter range mode (assuming 3=2 and 4=3)?
>>> On 17 Feb, 2012, at 9:35 PM, Mark Webb-Johnson wrote:
>>> Michael,
>>> I tried issuing the commands manually on the can bus and can switch
>>> modes shown on the VDS.
>>> N.B. There is a bug in the Android App on the marketplace - it gets the
>>> mode numbers wrong (I guess 0..3 not 0,1,3,4).
>>> I'm implementing this in the iPhone App tonight, so should be able to
>>> test later.
>>> On 17 Feb, 2012, at 9:11 PM, Michael Stegen wrote:
>>> I can confirm that switching between charge modes does not work 100%.
>>> I tried switching to range mode, and then start charging from the app.
>>> The battery indicator in the car changes, i.e. the top of the battery is
>>> visible.
>>> Range does not change, also charge mode visible on the VDS does not
>>> change (still standard charging)
>>> On the (Android) app , it's shows the same. After i stopped the
>>> charging, i received a SMS that does not start with Range - or Standard -
>>> just "Charging Stopped, ideal range ..etc"
>>> Tonight i'll try to send the commands manually on the CAN bus, to see if
>>> i see any difference in behaviour.
>>> Btw, i do receive a "Hello World" push message on my android phone, but
>>> not on the Ipad.
>>> I'm not using any testflight version anymore, but the one from the
>>> appstore.
>>> Btw2, when a charge is stopped, i used to receive a push message + SMS,
>>> this somehow does not work anymore for me. I only receive the SMS
>>> Btw3, the car powers up fine, and starts charging, even if left unused
>>> (but connected) for over a day.
>>> -Michael
>>> Op 17-2-2012 8:06, Mark Webb-Johnson schreef:
>>> P.S. Could someone fix the display so it reads Range Mode instead of
>>> Standard Mode when switched from standard to range? (Much appreciated.)
>>> Is this Android App?
>>> If so, Sonny (again): modes are 0=standard,
>>> 1=storage,3=range,4=performance
>>> P.S. What happened to mode 2? Did there used to be a mystery fifth
>>> mode?
>>> On 17 Feb 2012, at 2:59 PM, William Petefish wrote:
>>> Mark,
>>> Yes, fully repeatable, reproducible, and verifiable.
>>> When not woken up first, none of the commands work.
>>> I will restart the module and try further.
>>> It will disarm the alarm and allow it to be driven.
>>> William
>>> On Fri, Feb 17, 2012 at 12:51 AM, Mark Webb-Johnson <
>>> mark at webb-johnson.net> wrote:
>>>> William,
>>>> Is it repeatable?
>>>> ie; plug in, stop charge. wait 5 minutes until coolant pump turns
>>>> off, then try start charge from the app.
>>>> Also, are other commands working (like lock/unlock)?
>>>> After setting the feature for write-enabled CAN bus, you need to
>>>> restart the module. If not, none of the commands will work. If at least one
>>>> of the commands is working, then that is fine.
>>>> Regards, Mark.
>>>> P.S. Not wishing to hijack this thread, but since you are in the USA
>>>> - could you test the lock/unlock commands for us on your US car?
>>>> Supposedly, the US cars don't have an immobiliser so that the UNLOCK
>>>> command will disable the alarm and allow the car to be driven. Please try
>>>> and let us know.
>>>> On 17 Feb 2012, at 2:35 PM, William Petefish wrote:
>>>> Mark,
>>>> Yes, I did and to no avail. I had purposefully let the car sit until
>>>> it went into power save mode and tried again, no joy.
>>>> Might it have something to do with the new FW on the roadster? (4.6.4
>>>> I think is the FW that is on mine.) My roadster is a 2.5.
>>>> William
>>>> On Fri, Feb 17, 2012 at 12:29 AM, Mark Webb-Johnson <
>>>>> William:
>>>>> Current (1.2.0-rc3) code is:
>>>>> void can_tx_setchargecurrent(unsigned char current)
>>>>> while (TXB0CONbits.TXREQ) {} // Loop until TX is done
>>>>> TXB0CON = 0;
>>>>> TXB0SIDL = 0b01000000; // Setup 0x102
>>>>> TXB0SIDH = 0b00100000; // Setup 0x102
>>>>> TXB0D0 = 0x05;
>>>>> TXB0D1 = 0x02;
>>>>> TXB0D2 = 0x00;
>>>>> TXB0D3 = 0x00;
>>>>> TXB0D4 = current;
>>>>> TXB0D5 = 0x00;
>>>>> TXB0D6 = 0x00;
>>>>> TXB0D7 = 0x00;
>>>>> TXB0DLC = 0b00001000; // data length (8)
>>>>> TXB0CON = 0b00001000; // mark for transmission
>>>>> can_tx_wakeup(); // Also, wakeup the car if necessary
>>>>> void can_tx_wakeup(void)
>>>>> TXB0CON = 0;
>>>>> TXB0D0 = 0x0a;
>>>>> TXB0DLC = 0b00000001; // data length (8)
>>>>> That should work. Pre-rc3, I used to see this, but since rc3 it has
>>>>> been ok for me.
>>>>> Maybe the bus was busy and lost the wakeup message? Did you try
>>>>> sending any other commands, or repeating the start charge command?
>>>>> What is the version of your car (2.x or 1.5?).
>>>>> Regards, Mark.
>>>>> P.S. There is also a specific command C,18 that calls the CAN wakeup
>>>>> function. Not sure if the Android App supports it or not.
>>>>> On 17 Feb 2012, at 2:22 PM, William Petefish wrote:
>>>>> Mark,
>>>>> Feature Needed: Wake Up command.
>>>>> I tried to send the start charge command from my android phone and
>>>>> it wouldn't start to charge or change charging mode, etc. without being
>>>>> woken up by opening/closing the doors/trunk/remote/etc.
>>>>> I am using the latest release (1.20) and the Android app.
>>>>> William
>>>>> OvmsDev mailing list
>>> OvmsDev mailing listOvmsDev at lists.teslaclub.hkhttp://lists.teslaclub.hk/mailman/listinfo/ovmsdev
>>> Stegen Electronics
>>> Kwartslaan 95
>>> 3162 RD Rhoon
>>> The Netherlands
>>> Tel: +31 10-5016960www.stegen.com
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20120217/a46170fc/attachment-0001.html>
