[Ovmsdev] 1.2.0-rc3 tire pressure monitoring system
Tue Feb 14 10:44:07 HKT 2012
Michael,
Thanks for the feedback.
> - my EU 2.5 Roadster Sport have no tire pressure monitoring system installed, the iOS App shows invalid temp an pressure values
Seems to be an invalid tpms record (dating back to 2012-02-08 15:35:58). I have cleared it.
> - Not able to receive any PUSH Messages via the iOS App, maybe a configuration or server (64.111.70.40) issue …
Yes, that server has not been provisioned for PUSH yet. The main 202.52.42.80 server should be ok (and I think you've switched to that one).
> - I enabled the CAN write Feature by sending “FEATURE 15 1” SMS command – but how to check if it’s enabled?
The Android App on the store supports this today. The iOS App is a little behind (but will look better when done) - I should have a testflight release later this week.
On 14 Feb 2012, at 12:39 AM, Michael Gerber gerber energie systeme wrote:
> Hi all,
> yesterday I flashed the new 1.2.0-rc3 firmware, while testing I found some issues:
> <image001.jpg>
> But hey – great work!
> mit sonnigen grüßen vom kaiserstuhl, with sunny regards
> Michael Gerber
> Geschäftsführer
> <image003.jpg>
> gerber energie systeme gmbh
> Coulonger str. 8
> 79346 Endingen, Germany
> Telefon: +49 (0) 7642 92118-22
> Telefax: +49 (0) 7642 92118-18
> Mail michael.gerber at gerber.tv
> http://www.gerber.tv/
> This message may contain confidential or privileged
> information and is intended only for the use of the
> addressee named above. If you are not the intended
> recipient of this message, you are hereby notified
> that you must not use, copy, disclose or take any
> action based on this message or information herein.
> If you have received this message by error, please
> advise the sender immediately and delete this message.
> Thank you for your cooperation.
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20120214/7dd4e07a/attachment-0001.html>
