[Ovmsdev] Problem building the project
Fri Dec 28 22:12:43 HKT 2012
Mark,
I'm working on Linux, MPLAB-X 1.41 & MCC18 3.40.
It seems only the windows version is broken?
Am 28.12.2012 14:23, schrieb Mark Webb-Johnson:
> Michael,
> Do you work under windows with MPLAB-X and MCC18?
> I had a look at Nikolay's machine, and it all seemed ok. Now trying to
> install on my laptop. Slow slow slow...
> Mark.
> On 28 Dec, 2012, at 6:06 PM, Michael Balzer <dexter at expeedo.de
> <mailto:dexter at expeedo.de>> wrote:
>> Hi Nikolay, welcome :-)
>> did you check the Google results for platform config specific hints
>> on this? Seems to be a quite common MPLAB problem.
>> Also, you cannot use the IDE configurations right off from the
>> repository, you need to edit them at least once, as MPLAB then
>> adjusts some internal paths +x. Some adjustment will be done
>> automatically on building to find a working compiler, but I wouldn't
>> rely on that to be complete. Also restarting MPLAB after that first
>> config change might be necessary, I had to do that a few times (but
>> on other errors).
>> Mark, I had to do this in commit
>> 9eaa71c1e6ccae21cf9dcfe8fd8a4e22666830ba:
>> - can_capapilities changed to rom pointer
>> ...because it wouldn't work otherwise, so I think the rom keyword
>> just declares the pointer type to be a rom address and is correct &
>> necessary.
>> Am 28.12.2012 01:28, schrieb Mark Webb-Johnson:
>>> Interesting. Michael Jochum had a similar error a few months back,
>>> but he was using an older MPLAB. He switched to mplab-x on his mac,
>>> and the problem went away, so we never tried upgrading his mplab on
>>> his PC.
>>> Can you double-check the project build settings for mcc18, and
>>> ensure all optimisations are enabled, and you are not doing a debug
>>> build?
>>> Unless anyone else has any ideas, I think I'll have to try to
>>> install mplab-x on my windows laptop and see if I can recreate the
>>> problem.
>>> P.S. The other day, I did notice that the "rom BOOL" function
>>> definitions in vehicle.c are incorrect. ROM constants obviously
>>> can't be modified, but these needs to be. But, it seems that the
>>> mcc18 compiler can't handle rom based pointers to code anyway, so
>>> auto-changes them to ram based variables for us (which is why we
>>> never noticed the problem before). I don't think this is your
>>> problem, but perhaps you could try to change the "rom BOOL
>>> (*vehicle_fn_*" definitions in vehicle.h and vehicle.c to just "BOOL
>>> ..." (ie; without the ROM prefix) and see if that fixes anything.
>>> On 28 Dec, 2012, at 6:53 AM, Nikolay Shishkov wrote:
>>>> Yes, I am running mplab x ide 1.60, and the mcc18, I have selected
>>>> V2_Experimental (followed the instructions in
>>>> Firmware-Development.odt)...
>>>> Below is the full output, hope it provides more info:
>>>> CLEAN SUCCESSFUL (total time: 1s)
>>>> make -f nbproject/Makefile-V2_Experimental.mk SUBPROJECTS= .build-conf
>>>> make[1]: Entering directory
>>>> `C:/Documents_and_Settings/Niko/MPLABXProjects/OVMS.X'
>>>> dist/V2_Experimental/production/OVMS.X.production.hex
>>>> make[2]: Entering directory
>>>> "C:\Program Files\Microchip\mplabc18\v3.40\bin\mcc18.exe"
>>>> -p18F2685 -k -DOVMS_SPEEDO_EXPERIMENT -DOVMS_CAR_NONE
>>>> -DOVMS_CAR_TESLAROADSTER -DOVMS_CAR_VOLTAMPERA
>>>> -DOVMS_CAR_RENAULTTWIZY -DOVMS_CAR_OBDII -DOVMS_HW_V2
>>>> -DOVMS_DIAGMODULE -DOVMS_INTERNALGPS -ml -oa- -I "C:\Program
>>>> Files\Microchip\mplabc18\v3.40\bin"\\..\\h <smb://..//h> -fo
>>>> build/V2_Experimental/production/UARTIntC.o UARTIntC.c
>>>> build/V2_Experimental/production/crypt_base64.o crypt_base64.c
>>>> build/V2_Experimental/production/crypt_hmac.o crypt_hmac.c
>>>> build/V2_Experimental/production/crypt_md5.o crypt_md5.c
>>>> build/V2_Experimental/production/crypt_rc4.o crypt_rc4.c
>>>> build/V2_Experimental/production/led.o led.c
>>>> build/V2_Experimental/production/net.o net.c
>>>> build/V2_Experimental/production/net_msg.o net_msg.c
>>>> build/V2_Experimental/production/net_sms.o net_sms.c
>>>> build/V2_Experimental/production/ovms.o ovms.c
>>>> build/V2_Experimental/production/params.o params.c
>>>> build/V2_Experimental/production/utils.o utils.c
>>>> build/V2_Experimental/production/inputs.o inputs.c
>>>> build/V2_Experimental/production/diag.o diag.c
>>>> build/V2_Experimental/production/vehicle_teslaroadster.o
>>>> vehicle_teslaroadster.c
>>>> build/V2_Experimental/production/vehicle_twizy.o vehicle_twizy.c
>>>> build/V2_Experimental/production/vehicle_voltampera.o
>>>> vehicle_voltampera.c
>>>> build/V2_Experimental/production/vehicle.o vehicle.c
>>>> build/V2_Experimental/production/vehicle_none.o vehicle_none.c
>>>> build/V2_Experimental/production/vehicle_obdii.o vehicle_obdii.c
>>>> "C:\Program Files\Microchip\mplabc18\v3.40\bin\mplink.exe"
>>>> -p18f2685 -w -m"build/memorymap" -z__MPLAB_BUILD=1 -u_CRUNTIME
>>>> -l "C:\Program Files\Microchip\mplabc18\v3.40\bin"\\..\\lib
>>>> <smb://..//lib> -o
>>>> dist/V2_Experimental/production/OVMS.X.production.cof
>>>> MPLINK 4.40, Linker
>>>> Device Database Version 1.3
>>>> Copyright (c) 1998-2011 Microchip Technology Inc.
>>>> Error - section '.code_vehicle.o' can not fit the section. Section
>>>> '.code_vehicle.o' length=0x000004f4
>>>> Errors : 1
>>>> make[2]: Leaving directory
>>>> make[1]: Leaving directory
>>>> make[2]: ***
>>>> [dist/V2_Experimental/production/OVMS.X.production.hex] Error 1
>>>> make[1]: *** [.build-conf] Error 2
>>>> make: *** [.build-impl] Error 2
>>>> BUILD FAILED (exit value 2, total time: 1m 7s)
>>>> *From:* Mark Webb-Johnson <mark at webb-johnson.net
>>>> <mailto:mark at webb-johnson.net>>
>>>> *To:* OVMS Developers <ovmsdev at lists.teslaclub.hk
>>>> <mailto:ovmsdev at lists.teslaclub.hk>>
>>>> *Sent:* Thursday, December 27, 2012 11:26 PM
>>>> *Subject:* Re: [Ovmsdev] Problem building the project
>>>> Did you download mplab-x (the Java environment), and mcc18 (the
>>>> microchip c compiler)?
>>>> Regards, Mark
>>>> On 28 Dec, 2012, at 5:45 AM, Nikolay Shishkov <nshishkov at yahoo.com
>>>> <mailto:nshishkov at yahoo.com>> wrote:
>>>>> Hello,
>>>>> This is my first message, I am trying to get the module talking to
>>>>> Think City EV.
>>>>> I installed the iDE and compiler, downloaded the repository, opened
>>>>> the project and did "Clean and Build Project" and got this error.
>>>>> I searched the list, and the forum and did not find any reference to
>>>>> this error. Any idea?
>>>>> Could it be that I have not connected the pic3 and the board?
>>>>> Thanks in advance,
>>>>> Nikolay
>>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20121228/c0b31d49/attachment.htm>
Type: text/x-vcard
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20121228/c0b31d49/attachment-0002.vcf>
