[Ovmsdev] Android code for OVMS
    Thu Dec 13 21:11:36 HKT 2012
Michael,
I think the memory issue is just the amount of RAM available. The vehicle list uses dynamically re-scaled hi-res vehicle images, and that seems to use a lot of ram. Eugene has just re-written that portion of the code, along with a lot of other UI enhancements, but I'm having trouble getting his changes to compile. I think I'm missing some new libraries. Hopefully I should be able to resolve this tonight.
Not so sure about the application installation issue. I used to have installation issues, and found it to be Android ADB timeouts. In eclipse, I went to Eclipse/Preferences/Android/DDMS and changed "ADB Connection Timeout" from 5000ms to 15000ms.
On 12 Dec, 2012, at 2:41 AM, Michael Balzer <dexter at expeedo.de> wrote:
> Mark,
> it will run in the emulator until I try to open the vehicle tab (tab 2). According to the log, it tries to allocate some huge amount of memory:
> 12-11 19:39:17.044: D/dalvikvm(401): GC_EXTERNAL_ALLOC freed 918K, 53% free 2995K/6343K, external 2284K/2709K, paused 39ms
> 12-11 19:39:17.194: D/dalvikvm(401): GC_EXTERNAL_ALLOC freed 9K, 53% free 2987K/6343K, external 3723K/3751K, paused 32ms
> 12-11 19:39:17.294: D/dalvikvm(401): GC_EXTERNAL_ALLOC freed <1K, 53% free 2989K/6343K, external 5162K/5548K, paused 32ms
> 12-11 19:39:17.374: D/dalvikvm(401): GC_EXTERNAL_ALLOC freed <1K, 53% free 2991K/6343K, external 7321K/7345K, paused 33ms
> 12-11 19:39:17.444: D/dalvikvm(401): GC_EXTERNAL_ALLOC freed <1K, 53% free 2993K/6343K, external 8794K/10041K, paused 34ms
> 12-11 19:39:17.464: E/dalvikvm-heap(401): 1302960-byte external allocation too large for this process.
> 12-11 19:39:17.494: E/GraphicsJNI(401): VM won't let us allocate 1302960 bytes
> 12-11 19:39:17.494: D/dalvikvm(401): GC_FOR_MALLOC freed <1K, 53% free 2993K/6343K, external 8794K/10041K, paused 19ms
> 12-11 19:39:17.504: D/skia(401): --- decoder->decode returned false
> 12-11 19:39:17.504: D/AndroidRuntime(401): Shutting down VM
> 12-11 19:39:17.504: W/dalvikvm(401): threadid=1: thread exiting with uncaught exception (group=0x40015560)
> 12-11 19:39:17.524: E/AndroidRuntime(401): FATAL EXCEPTION: main
> 12-11 19:39:17.524: E/AndroidRuntime(401): java.lang.RuntimeException: Unable to start activity ComponentInfo{com.openvehicles.OVMS/com.openvehicles.OVMS.ui.TabCar}: android.view.InflateException: Binary XML file line #55: Error inflating class <unknown>
> 12-11 19:39:17.524: E/AndroidRuntime(401):     at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:1647)
> 12-11 19:39:17.524: E/AndroidRuntime(401):     at android.app.ActivityThread.startActivityNow(ActivityThread.java:1487)
> 12-11 19:39:17.524: E/AndroidRuntime(401):     at android.app.LocalActivityManager.moveToState(LocalActivityManager.java:127)
> 12-11 19:39:17.524: E/AndroidRuntime(401):     at android.app.LocalActivityManager.startActivity(LocalActivityManager.java:339)
> 12-11 19:39:17.524: E/AndroidRuntime(401):     at android.widget.TabHost$IntentContentStrategy.getContentView(TabHost.java:654)
> 12-11 19:39:17.524: E/AndroidRuntime(401):     at android.widget.TabHost.setCurrentTab(TabHost.java:326)
> 12-11 19:39:17.524: E/AndroidRuntime(401):     at android.widget.TabHost$2.onTabSelectionChanged(TabHost.java:132)
> 12-11 19:39:17.524: E/AndroidRuntime(401):     at android.widget.TabWidget$TabClickListener.onClick(TabWidget.java:456)
> I thought that could be due to the VM. But if I try to install the self-signed .apk on my phone, the installation simply aborts with "application not installed" after accepting the rights, no further error message displayed. I've got an HTC DHD running the latest (HTC!) Android version 2.3.5 API level 10. Emulator is configured for API level 10 (2.3.3) as well.
> That's my first ADK contact, so maybe I'm missing something.
> Am 11.12.2012 03:56, schrieb Mark Webb-Johnson:
>> It should build, but is not yet feature complete.
>> What is the error you are getting?
>> On 11 Dec, 2012, at 3:01 AM, Michael Balzer wrote:
>>> Mark, Eugene(?),
>>> Am 22.10.2012 02:47, schrieb Mark Webb-Johnson:
>>>> The OVMS Android project on github is here:
>>>> https://github.com/markwj/Open-Vehicle-Android
>>> I've got some problems getting the current version from the repo to work. Should that be usable or is it unstable?
>>> Thanks,
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20121213/318bf957/attachment.htm>
