[Ovmsdev] Problem building the project
Sat Dec 29 01:25:08 HKT 2012
Piotr and I struggled with this issue in June, so it's been a problem for a
while. I'm glad to hear it wasn't just me.
    Tom
on 12/28/12 6:12 AM, Michael Balzer wrote:
> Mark,
> I'm working on Linux, MPLAB-X 1.41 & MCC18 3.40.
> It seems only the windows version is broken?
> Am 28.12.2012 14:23, schrieb Mark Webb-Johnson:
>> Michael,
>> Do you work under windows with MPLAB-X and MCC18?
>> I had a look at Nikolay's machine, and it all seemed ok. Now trying to
>> install on my laptop. Slow slow slow...
>> Mark.
>> On 28 Dec, 2012, at 6:06 PM, Michael Balzer <dexter at expeedo.de
>>> Hi Nikolay, welcome :-)
>>> did you check the Google results for platform config specific hints
>>> on this? Seems to be a quite common MPLAB problem.
>>> Also, you cannot use the IDE configurations right off from the
>>> repository, you need to edit them at least once, as MPLAB then
>>> adjusts some internal paths +x. Some adjustment will be done
>>> automatically on building to find a working compiler, but I wouldn't
>>> rely on that to be complete. Also restarting MPLAB after that first
>>> config change might be necessary, I had to do that a few times (but
>>> on other errors).
>>> Mark, I had to do this in commit
>>> 9eaa71c1e6ccae21cf9dcfe8fd8a4e22666830ba:
>>>     - can_capapilities changed to rom pointer
>>> ...because it wouldn't work otherwise, so I think the rom keyword
>>> just declares the pointer type to be a rom address and is correct &
>>> necessary.
>>> Am 28.12.2012 01:28, schrieb Mark Webb-Johnson:
>>>> Interesting. Michael Jochum had a similar error a few months back,
>>>> but he was using an older MPLAB. He switched to mplab-x on his mac,
>>>> and the problem went away, so we never tried upgrading his mplab on
>>>> his PC.
>>>> Can you double-check the project build settings for mcc18, and
>>>> ensure all optimisations are enabled, and you are not doing a debug
>>>> build?
>>>> Unless anyone else has any ideas, I think I'll have to try to
>>>> install mplab-x on my windows laptop and see if I can recreate the
>>>> problem.
>>>> Regards, Mark.
>>>> P.S. The other day, I did notice that the "rom BOOL" function
>>>> definitions in vehicle.c are incorrect. ROM constants obviously
>>>> can't be modified, but these needs to be. But, it seems that the
>>>> mcc18 compiler can't handle rom based pointers to code anyway, so
>>>> auto-changes them to ram based variables for us (which is why we
>>>> never noticed the problem before). I don't think this is your
>>>> problem, but perhaps you could try to change the "rom BOOL
>>>> (*vehicle_fn_*" definitions in vehicle.h and vehicle.c to just "BOOL
>>>> ..." (ie; without the ROM prefix) and see if that fixes anything.
>>>> On 28 Dec, 2012, at 6:53 AM, Nikolay Shishkov wrote:
>>>>> Yes, I am running mplab x ide 1.60, and the mcc18, I have selected
>>>>> V2_Experimental  (followed the instructions in
>>>>> Firmware-Development.odt)...
>>>>> Below is the full output, hope it provides more info:
>>>>> CLEAN SUCCESSFUL (total time: 1s)
>>>>> make -f nbproject/Makefile-V2_Experimental.mk SUBPROJECTS= .build-conf
>>>>> make[1]: Entering directory
>>>>> `C:/Documents_and_Settings/Niko/MPLABXProjects/OVMS.X'
>>>>> dist/V2_Experimental/production/OVMS.X.production.hex
>>>>> make[2]: Entering directory
>>>>> "C:\Program Files\Microchip\mplabc18\v3.40\bin\mcc18.exe"
>>>>>  -p18F2685 -k -DOVMS_SPEEDO_EXPERIMENT -DOVMS_CAR_NONE
>>>>> -DOVMS_CAR_TESLAROADSTER -DOVMS_CAR_VOLTAMPERA
>>>>> -DOVMS_CAR_RENAULTTWIZY -DOVMS_CAR_OBDII -DOVMS_HW_V2
>>>>> -DOVMS_DIAGMODULE -DOVMS_INTERNALGPS -ml -oa-  -I "C:\Program
>>>>> Files\Microchip\mplabc18\v3.40\bin"\\..\\h <smb://..//h>  -fo
>>>>> build/V2_Experimental/production/UARTIntC.o   UARTIntC.c
>>>>> build/V2_Experimental/production/crypt_base64.o   crypt_base64.c
>>>>> build/V2_Experimental/production/crypt_hmac.o   crypt_hmac.c
>>>>> build/V2_Experimental/production/crypt_md5.o   crypt_md5.c
>>>>> build/V2_Experimental/production/crypt_rc4.o   crypt_rc4.c
>>>>> build/V2_Experimental/production/led.o led.c
>>>>> build/V2_Experimental/production/net.o net.c
>>>>> build/V2_Experimental/production/net_msg.o   net_msg.c
>>>>> build/V2_Experimental/production/net_sms.o   net_sms.c
>>>>> build/V2_Experimental/production/ovms.o   ovms.c
>>>>> build/V2_Experimental/production/params.o   params.c
>>>>> build/V2_Experimental/production/utils.o   utils.c
>>>>> build/V2_Experimental/production/inputs.o   inputs.c
>>>>> build/V2_Experimental/production/diag.o   diag.c
>>>>> build/V2_Experimental/production/vehicle_teslaroadster.o
>>>>> vehicle_teslaroadster.c
>>>>> build/V2_Experimental/production/vehicle_twizy.o   vehicle_twizy.c
>>>>> build/V2_Experimental/production/vehicle_voltampera.o
>>>>> vehicle_voltampera.c
>>>>> build/V2_Experimental/production/vehicle.o   vehicle.c
>>>>> build/V2_Experimental/production/vehicle_none.o   vehicle_none.c
>>>>> build/V2_Experimental/production/vehicle_obdii.o   vehicle_obdii.c
>>>>> "C:\Program Files\Microchip\mplabc18\v3.40\bin\mplink.exe"
>>>>>  -p18f2685  -w  -m"build/memorymap"  -z__MPLAB_BUILD=1  -u_CRUNTIME
>>>>> -l "C:\Program Files\Microchip\mplabc18\v3.40\bin"\\..\\lib
>>>>> <smb://..//lib>  -o
>>>>> dist/V2_Experimental/production/OVMS.X.production.cof
>>>>> MPLINK 4.40, Linker
>>>>> Device Database Version 1.3
>>>>> Copyright (c) 1998-2011 Microchip Technology Inc.
>>>>> Error - section '.code_vehicle.o' can not fit the section. Section
>>>>> '.code_vehicle.o' length=0x000004f4
>>>>> Errors    : 1
>>>>> make[2]: Leaving directory
>>>>> make[1]: Leaving directory
>>>>> make[2]: ***
>>>>> [dist/V2_Experimental/production/OVMS.X.production.hex] Error 1
>>>>> make[1]: *** [.build-conf] Error 2
>>>>> make: *** [.build-impl] Error 2
>>>>> BUILD FAILED (exit value 2, total time: 1m 7s)
>>>>> *From:* Mark Webb-Johnson <mark at webb-johnson.net
>>>>> <mailto:mark at webb-johnson.net>>
>>>>> *To:* OVMS Developers <ovmsdev at lists.teslaclub.hk
>>>>> <mailto:ovmsdev at lists.teslaclub.hk>>
>>>>> *Sent:* Thursday, December 27, 2012 11:26 PM
>>>>> *Subject:* Re: [Ovmsdev] Problem building the project
>>>>> Did you download mplab-x (the Java environment), and mcc18 (the
>>>>> microchip c compiler)?
>>>>> Regards, Mark
>>>>> On 28 Dec, 2012, at 5:45 AM, Nikolay Shishkov <nshishkov at yahoo.com
>>>>> <mailto:nshishkov at yahoo.com>> wrote:
>>>>>> Hello,
>>>>>> This is my first message, I am trying to get the module talking to
>>>>>> Think City EV.
>>>>>> I installed the iDE and compiler, downloaded the repository, opened
>>>>>> the project and did "Clean and Build Project" and got this error.
>>>>>> I searched the list, and the forum and did not find any reference to
>>>>>> this error. Any idea?
>>>>>> Could it be that I have not connected the pic3 and the board?
>>>>>> Thanks in advance,
>>>>>> Nikolay
>>>>>> OvmsDev mailing list
>>>>>> OvmsDev at lists.teslaclub.hk <mailto:OvmsDev at lists.teslaclub.hk>
