[Ovmsdev] Volt/Ampera
mikeljo at me.com
mikeljo at me.com
Fri Dec 28 19:04:31 HKT 2012
Hi,
you can ask him yourself. He is in the List.
Hi Johannes!
I think he is doing some tests today.
Bye
Am 28.12.2012 um 01:41 schrieb Mark Webb-Johnson <mark at webb-johnson.net>:
> Can he provide the logs from the moment the DashDAQ is connected? Perhaps 10 seconds without charging, then start the charge and continue to monitor for 1 minute.
> It seems possible that this is enabled by turning on a monitoring mode, but unexpected. This sort of thing would normally just be transmitted as part of the normal message stream.
> Regards, Mark
> On 27 Dec, 2012, at 11:58 PM, mikeljo at me.com wrote:
>> Am 27.12.2012 um 01:11 schrieb Mark Webb-Johnson <mark at webb-johnson.net>:
>>> Now, on to the other messages (I spoke about yesterday in the other thread). I'll try to drum up some interest in the forums to see if anyone can help with the decodes. It would be good if you could do the same.
>> And here some first results from tachy:
>> CANUSB mit DashDAQ kombiniert bringts! Ich habe soeben den Code für das Ladegerät (Ladestrom/Ladespannung) rausbekommen:
>> 5EC Byte 3 Ladestrom Einheit 0.2 A (Bsp: 14.2 A = 47h)
>> 5EC Byte 4 Ladespannung Einheit 2 V (Bsp: 222V = 6Fh)
>> He works with a DashDAQ and a CANUSB, both connected with a ODB2 Y-Cable.
>> So he find the Charging Current und Charging Voltage:
>> 5EC Byte 3 Charge Current Unit 0.2 A (Example: 14.2 A = 47h)
>> 5EC Byte 4 Charge Voltage Unit 2 V (Example: 222V = 6Fh)
>> Fast enough?
>> BUT!!! This IDs doesn't exist in my Logs. i Think the DasDaq send a Command to get this ID.
>> Bye
>> michael
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20121228/df68c868/attachment.html>
