[Ovmsdev] sprintf / crashes
Wed Dec 26 21:21:55 HKT 2012
Michael,
The ANSI style is ok, with tabs converted to spaces, and indentation set to 2. I personally prefer the braces indented as well, but mplabx doesn't seem to be able to do that.
On 22 Dec, 2012, at 2:06 AM, Michael Balzer <dexter at expeedo.de> wrote:
> Mark,
> Am 20.12.2012 02:29, schrieb Mark Webb-Johnson:
>> I did make some minor layout fixes (where the indentation was wrong - I think you are using 4 spaces, or perhaps tabs, where the rest of the project uses 2).
> My personal C/C++ style is no common standard, so I'll try to remember reformatting everything at least before committing.
> I've seen the MPLAB editor supports a range of standard formatting styles, among which the GNU style seems to be what you're using -- right? I'll use that one now. Any changes to the style config needed?
