[Ovmsdev] Wrong Roadster Data
Tue Dec 18 02:51:19 HKT 2012
Rebooting the device fixed the problem.
I didn't get your email until after I had rebooted, but if it happens again
I'll try the reset command.
    Tom
on 12/16/12 4:42 PM, Mark Webb-Johnson wrote:
> Tom,
> I think this is definitely Michael's can-bus-lockup issue.
> The problem seems to be that if the can bus overflows (or gets some other sort
> of error?) then it sets a flag in the controller, and the controller won't
> deliver any more messages until the flag is cleared. The bus still has
> messages, but they don't get to the OVMS App. The OVMS code in the car will
> keep reporting the old bus values - the only indication would be the stale
> indicators would all go stale as there were no more messages seen by the code.
> What Michael has done for the Twizy code (where he was seeing this often) is
> to add a once-a-second check for the can bus error flag, and clear the
> controller error condition if he sees it. He reported that solved his problem.
> With the v2 code we are working on, I'm taking his can bus error clear code
> and making it a standard for all cars. The roadster code will benefit from
> this.
> I think that if you reset the module (either sms RESET, or use the smartphone
> module reset function), the error should clear (as a reset will re-iniitialse
> the can bus controller. Can you try this? You'll know if it works if the SOC
> immediately switches to the correct value.
> On 17 Dec, 2012, at 12:07 AM, Tom Saxton wrote:
>> Opening the door didn't help.
>> I was wondering if I was getting data from another Roadster, so I checked
>> the Location view. It's showing the spot where the car was parked yesterday
>> afternoon, and in fact all of the data is consistent with that: SOC and
>> locked status. Since then, the car has been driven twice and charged, so
>> plenty of opportunity to get current CAN bus readings.
>> The other odd thing is that it shows it's been parked for 5 minutes every
>> time I update it.
>> The only thing unusual yesterday was that I realized I hadn't locked the car
>> a couple of minutes after we parked, so I used OVMS to lock the car, and
>> checked the Car view to confirm it was locked.
>> Could that have frozen things for some reason?
>> I'll try rebooting the car module before I drive it this morning.
>>    Tom
>> on 12/16/12 6:29 AM, Mark Webb-Johnson wrote:
>>> Tom,
>>> I just checked the server logs, and the car seems to be online.
>>> 2012-12-16 09:22:12.710176 -0500 info  main: #65 C SAX217 msg handle S
>>> 73,M,-1,0,stopped,standard,135,105,32,254,100,29,7,14,0,1,200,1
>>> It is reporting 73%.
>>> Maybe some issue with the message reception on the can bus? Can you try
>>> opening a door with the app running, and see if it registers?
>>> [Michael, working on the Twizy, found an issue where the can bus buffers
>>> could
>>> overflow, causing no more can messages to be received - I haven't seen it on
>>> the Roadster before, but it is possible this is what you are seeing]
>>> On 16 Dec, 2012, at 10:23 PM, Tom Saxton <tom at idleloop.com> wrote:
>>>> There's something odd going on with OVMS and my Roadster this morning. I'm
>>>> seeing data that claims to be live, but which is totally wrong.
>>>> I got home last night with a 50% charge and set the Roadster to charge at 2
>>>> am. When I checked it this morning at 6:20, OVMS said the car was at 73%,
>>>> live, parked for 5 minutes, and locked. When I checked the car, none of
>>>> those were true. The car's at 97%, has been parked 9.5 hours, and is
>>>> unlocked.
>>>> I've never seen OVMS be wrong and claim to be "live".
>>>>   Tom
>>>> OvmsDev mailing list
