[Ovmsdev] Wrong Roadster Data
Mon Dec 17 08:42:59 HKT 2012
Tom,
I think this is definitely Michael's can-bus-lockup issue.
The problem seems to be that if the can bus overflows (or gets some other sort of error?) then it sets a flag in the controller, and the controller won't deliver any more messages until the flag is cleared. The bus still has messages, but they don't get to the OVMS App. The OVMS code in the car will keep reporting the old bus values - the only indication would be the stale indicators would all go stale as there were no more messages seen by the code.
What Michael has done for the Twizy code (where he was seeing this often) is to add a once-a-second check for the can bus error flag, and clear the controller error condition if he sees it. He reported that solved his problem.
With the v2 code we are working on, I'm taking his can bus error clear code and making it a standard for all cars. The roadster code will benefit from this.
I think that if you reset the module (either sms RESET, or use the smartphone module reset function), the error should clear (as a reset will re-iniitialse the can bus controller. Can you try this? You'll know if it works if the SOC immediately switches to the correct value.
On 17 Dec, 2012, at 12:07 AM, Tom Saxton wrote:
> Opening the door didn't help.
> I was wondering if I was getting data from another Roadster, so I checked
> the Location view. It's showing the spot where the car was parked yesterday
> afternoon, and in fact all of the data is consistent with that: SOC and
> locked status. Since then, the car has been driven twice and charged, so
> plenty of opportunity to get current CAN bus readings.
> The other odd thing is that it shows it's been parked for 5 minutes every
> time I update it.
> The only thing unusual yesterday was that I realized I hadn't locked the car
> a couple of minutes after we parked, so I used OVMS to lock the car, and
> checked the Car view to confirm it was locked.
> Could that have frozen things for some reason?
> I'll try rebooting the car module before I drive it this morning.
>    Tom
> on 12/16/12 6:29 AM, Mark Webb-Johnson wrote:
>> Tom,
>> I just checked the server logs, and the car seems to be online.
>> 2012-12-16 09:22:12.710176 -0500 info  main: #65 C SAX217 msg handle S
>> 73,M,-1,0,stopped,standard,135,105,32,254,100,29,7,14,0,1,200,1
>> It is reporting 73%.
>> Maybe some issue with the message reception on the can bus? Can you try
>> opening a door with the app running, and see if it registers?
>> [Michael, working on the Twizy, found an issue where the can bus buffers could
>> overflow, causing no more can messages to be received - I haven't seen it on
>> the Roadster before, but it is possible this is what you are seeing]
>> On 16 Dec, 2012, at 10:23 PM, Tom Saxton <tom at idleloop.com> wrote:
>>> There's something odd going on with OVMS and my Roadster this morning. I'm
>>> seeing data that claims to be live, but which is totally wrong.
>>> I got home last night with a 50% charge and set the Roadster to charge at 2
>>> am. When I checked it this morning at 6:20, OVMS said the car was at 73%,
>>> live, parked for 5 minutes, and locked. When I checked the car, none of
>>> those were true. The car's at 97%, has been parked 9.5 hours, and is
>>> unlocked.
>>> I've never seen OVMS be wrong and claim to be "live".
>>>   Tom
