[Ovmsdev] RFC: Battery status MSG protocol
Sun Dec 2 04:00:40 HKT 2012
Hi Mark,
this is my first draft of a battery data protocol as implemented in the
Twizy module 2.0 (see vehicle_twizy_battstatus_msgp()).
For each battery pack (min 1), a message of type "B" transports the
current state and collected min/max values:
// Output pack status:
// MP-0 B,<packnr>,<nr_of_cells>
// ,<volt_alertstatus>,<temp_alertstatus>
// ,<soc>,<soc_min>,<soc_max>
// ,<volt_act>,<volt_act_cellnom>
// ,<volt_min>,<volt_min_cellnom>
// ,<volt_max>,<volt_max_cellnom>
// ,<temp_act>,<temp_min>,<temp_max>
The units now are 1/100 % for the SOCs, 1/100 V for the voltages and 1
°C for the temperatures. Maybe floats are more readable / standard for
SOC & V?
Alert status are enums of...
0 = unknown
1 = nominal
2 = suspicious
3 = alert
4 = fail
For each cell in each pack, a message of type "H" transports the cell
details accordingly:
// Output cell status:
// MP-0 H,<packnr>,<cellnr>
// ,<volt_alertstatus>,<temp_alertstatus>,
// ,<volt_act>,<volt_min>,<volt_max>,<volt_maxdev>
// ,<temp_act>,<temp_min>,<temp_max>,<temp_maxdev>
Numbering of packs and cells begins at "1" to reserve "0" for an "all"
selector.
Alert status uses the same enum scheme as on the pack level.
Voltages on the cell level are in unit mV, temperatures in °C. The
maximum deviations are signed to reflect the direction of the deviation.
Of course, a cell need not be a physical cell, it's just the smallest
monitorable unit in a pack. Monitoring huge packs will not be possible
with the current OVMS hardware, unless we consider streaming all sensor
data to the server.
I thought about how much could be stored in the server now and had a
first look at the current server implementation. The primary key of
table "ovms_carmessages" would need to be changed, as it currently is
bound to just the message type character (and also case insensitive,
reducing the number of possible message types). The key would need to be
extended by the packnr on "B" messages and the pack + cellnr on "H"
messages.
So, generally speaking, we could introduce 2-3 key extension columns
that can be used dynamically based on the message type. That would also
enable storing of other historical records. To keep the database clean,
an expire mechanism could drop all rows older than e.g. 24 hours.
Please comment.
Type: text/x-vcard
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20121201/46b395fd/attachment.vcf>
