[Ovmsdev] Alarm messages
Jack West
jackduncanwest at gmail.com
Wed Aug 1 14:00:59 HKT 2012
On US 2.5 Roadsters the VDS shows "deactivating PIN lock" and requests the PIN to shut off the alarm. Using the key FOB to lock or unlock will also shut off the alarm. I'm curious if the VDS could be spoofed into sounding the alarm when the car is locked, by sending a message on the bus that says the door is open. It also seems that if the VDS always shows the PIN message when the alarm is sounding then it should be possible to send an alert via OVMS.
I don't have a CAN bus tool but I also don't have any neighbors to complain about car alarms continually sounding.
On Jul 26, 2012, at 1:24 AM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
> It would be good to find the 'alarm is sounding' code - anyone without neighbors to annoy?
> For 'sound the alarm', I seem to remember Scott saying sending the unlock code too fast caused a single beep - something like the sound made when you lock the car with the key fob too soon after closing the door.
> On 25 Jul, 2012, at 4:45 PM, Jack West <jackduncanwest at gmail.com> wrote:
>> Yes, I did mean "alarm is sounding". And along with that, "sound the alarm". I'm not sure if the VDS shows any message if the alarm sounds. I'll have to check.
>> Thanks
>> On Jul 25, 2012, at 1:25 AM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
>>> The alarm arm/disarm messages have been found. Do you mean "alarm is sounding"?
>>> I seem to remember the vds shows a message if the alarm is sounding?
>>> On 25 Jul, 2012, at 8:05 AM, Jack West <jackduncanwest at gmail.com> wrote:
>>>> Developers,
>>>> Has anyone decoded the alarm message on the can bus of the Roadster? Any ideas where it might be hiding?
>>>> Thanks,
>>>> Jack
>>>> OvmsDev mailing list
