[Ovmsdev] Alarm messages
Jack West jackduncanwest at gmail.com
Thu Aug 2 06:26:01 HKT 2012
In case anyone (with a can bus analyzer) is interested, the horn can be disabled by pulling the fuse (15A, #9 in fuse box).  Lights still flash on alarm.  Interestingly, using the key to open a locked car from the bottom of the door still sets off the alarm.
Jack
On Jul 26, 2012, at 1:24 AM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
> It would be good to find the 'alarm is sounding' code - anyone without neighbors to annoy?
> For 'sound the alarm', I seem to remember Scott saying sending the unlock code too fast caused a single beep - something like the sound made when you lock the car with the key fob too soon after closing the door.
> On 25 Jul, 2012, at 4:45 PM, Jack West <jackduncanwest at gmail.com> wrote:
>> Yes, I did mean "alarm is sounding".  And along with that, "sound the alarm".  I'm not sure if the VDS shows any message if the alarm sounds.  I'll have to check.
>> Thanks
>> On Jul 25, 2012, at 1:25 AM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
>>> The alarm arm/disarm messages have been found. Do you mean "alarm is sounding"?
>>> I seem to remember the vds shows a message if the alarm is sounding?
>>> On 25 Jul, 2012, at 8:05 AM, Jack West <jackduncanwest at gmail.com> wrote:
>>>> Developers,
>>>> Has anyone decoded the alarm message on the can bus of the Roadster?  Any ideas where it might be hiding?
>>>> Thanks,
>>>> Jack
>>>> OvmsDev mailing list
