[Ovmsdev] iPhone UI Request-For-Comments
Sat Apr 21 20:52:25 HKT 2012
Bennett,
> I really like the top-down view!
Yep, it certainly seems the least troublesome. let's see what Felix comes up with.
By the way, Sonny showed me the Android App this afternoon, with my test rally car. Not too bad. It keeps the car image static (pointing east) and uses a little blue marker to show direction. Something like what Tom mentioned. However, it doesn't look as smooth as the iPhone approach, as a car going west does have the blue marker to the left, but still looks to be driving backwards :-)
> If speed is easy, then how about adding:
> 1) Power Output in kW (is displayed on at least one VDS screen while driving)
> 2) Current/Peak g-Force, horsepower, and torque
> 3) Instantaneous/Average kWh/mile
Hmmm. None of those have been found on the CAN bus (yet). As it is on the VDS, it should be possible, but we haven't found it yet. The issue may be we need to be driving to see that and most of the can bus reverse engineers have been doing this on their own so far.
On 21 Apr, 2012, at 2:22 PM, Bennett Leeds wrote:
> I really like the top-down view!  That gets my vote without a doubt.
> Heck, from your demo I can even see that you're driving on the wrong
> side of the road!!  (At least for me, being an American, it's the
> wrong side. In Hong Kong, I know it's the correct side.)
> I think the 3D effect on the map doesn't help at all, and the
> flipping/upside down thing is way more distracting than cool. Assuming
> the  car icon is the same color as chosen, it'll be great.
> thanks,
> - Bennett
> On Fri, Apr 20, 2012 at 10:11 PM,  <ovmsdev-request at lists.teslaclub.hk> wrote:
>> Send OvmsDev mailing list submissions to
>>        ovmsdev at lists.teslaclub.hk
>> To subscribe or unsubscribe via the World Wide Web, visit
>>        http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
>> or, via email, send a message with subject or body 'help' to
>> You can reach the person managing the list at
>>        ovmsdev-owner at lists.teslaclub.hk
>> When replying, please edit your Subject line so it is more specific
>> than "Re: Contents of OvmsDev digest..."
>> Today's Topics:
>>   1. Re: iPhone UI Request-For-Comments (Bennett Leeds)
>>   2. Re: iPhone UI Request-For-Comments (Mark Webb-Johnson)
>> Message: 1
>> Date: Fri, 20 Apr 2012 21:18:10 -0700
>> From: Bennett Leeds <bennettleeds at gmail.com>
>> Subject: Re: [Ovmsdev] iPhone UI Request-For-Comments
>> To: OVMS Developers <OvmsDev at lists.teslaclub.hk>
>> Message-ID:
>>        <CAPBZZb-FeKrDtNg+Z9=s+vincBRFYY+e9woWbf3vsg_=RDWDOQ at mail.gmail.com>
>> Content-Type: text/plain; charset="iso-8859-1"
>> I'm surprised the "view of the car from the top" image didn't work -
>> that would have been my first thought.
>> If you are wedded to this image then my main suggestion is to flip the
>> image whenever it would be upside down. This might create some weird
>> effects on roads that are almost vertical as it changes from 89
>> degrees to 91 degrees, but maybe if the car image flips only at 85
>> degrees and 95 degrees rather than a hard line at 90 degrees (which is
>> true vertical) you'd lose the oscillating back and forth on near
>> vertical roads.
>> You might also remove the ground shadow from the car image.
>> If you're not wedded to a car image, then you could use the generic
>> GPS "you" image (see attached).
>> If you're in the mood to add features, seeing the current speed would be cool.
>> - Bennett
>> On Fri, Apr 20, 2012 at 9:00 PM,  <ovmsdev-request at lists.teslaclub.hk> wrote:
>>> ? ? ? ?ovmsdev at lists.teslaclub.hk
>>> ? ? ? ?http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
>>> ? ? ? ?ovmsdev-request at lists.teslaclub.hk
>>> ? ? ? ?ovmsdev-owner at lists.teslaclub.hk
>>> Today's Topics:
>>> ? 1. iPhone UI Request-For-Comments (Mark Webb-Johnson)
>>> Message: 1
>>> Date: Sat, 21 Apr 2012 00:06:56 +0800
>>> From: Mark Webb-Johnson <mark at webb-johnson.net>
>>> Subject: [Ovmsdev] iPhone UI Request-For-Comments
>>> Cc: felix bonnier <felix at bonnier.se>
>>> Message-ID: <59F93BDD-E090-4E5A-86C8-FB1801BB0DC5 at webb-johnson.net>
>>> Content-Type: text/plain; charset="us-ascii"
>>> Guys,
>>> I've been working on tidying and cleaning up the iPhone App, and am now looking at the Location tab.
>>> First thing I've done is revamp the code to handle location changes and support car bearing. I've also done an interface for social groups, and tidied up the object model for all this. The last step is to enable the display of cars for selected social groups.
>>> I've put a couple of youtube videos up to show what it looks like:
>>> http://www.youtube.com/watch?v=l6DmRPfX3_8
>>> http://www.youtube.com/watch?v=YxN16qN7h5E
>>> I'm interested in your opinion on the car image used. The problem is the rotation of the car, and the image perspective we use, leads to some strange upside-down appearances. I tried changing to the top-down car (as used on the "Car' tab to show TPMS, etc), but it really doesn't look nice.
>>> What do people think? Is it ok without re-doing a whole new set of images?
>>> P.S. The demo is done with a car called RALLY. The data comes from last summer's round-Hong-Kong-rally. We took GPS data from the Alpine head unit, with location streamed once every two seconds, and play it back as if a car is driving it (with car bearing derived very roughly as the bearing between the location now and the location 2 seconds ago - so it is a bit jumpy). Real Tesla Roadsters seem less jumpy on the direction (I guess they smooth the GPS data over more than 2 seconds). You can see another visualisation of the round Hong Kong rally data here.
>>> -------------- next part --------------
>>> An HTML attachment was scrubbed...
>>> URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20120421/73d79612/attachment-0001.html>
>>> End of OvmsDev Digest, Vol 3, Issue 19
>> A non-text attachment was scrubbed...
>> Type: image/jpeg
>> Desc: not available
>> URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20120420/0ae43fa1/attachment-0001.jpeg>
>> Message: 2
>> Date: Sat, 21 Apr 2012 13:11:35 +0800
>> To: OVMS Developers <ovmsdev at lists.teslaclub.hk>
>> Message-ID: <6F01D14C-928E-4365-8AD2-24D47D097D7D at webb-johnson.net>
>> Bennett,
>> A short video of the top-down view is:
>> http://youtu.be/ptDwV0qErOQ
>> It looks cleaner, but not so interesting ;-( I miss the 3D effect...
>> The other approach is to always keep the car looking right, and to rotate the map. That is theoretically possible, but I don't like so much (I like knowing north/south/east/west).
>> Speed is relatively easy, and I was going to tackle it later after the group cars were actually displayed on the map. In this re-work, I've make the map annotation for the car a self-contained object that has everything it needs to know about itself and draws itself. We can either use pop-ups when you touch a car, or just hover a little speedometer/parking sign over the car. We can also show battery SOC in a similar way.
>> P.S. I originally had the car vertical flipping as you suggest, but when I added the smooth-scrolling animation (which is so much better), things went crazy. The iPhone would animate the vehicle flip so you'd end up with a five second animation of the vehicle being sucked into a black hole in the map and then being spat out flipped upside down - every time the car moved a couple of degrees of north/south.
>>> vertical roads.
>>> - Bennett
>>>> Today's Topics:
>>>> Message: 1
>>>> Guys,
>>>> Regards, Mark.
>>> <GPSTriangle.jpeg>_______________________________________________
>> URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20120421/9d9ed217/attachment.html>
>> End of OvmsDev Digest, Vol 3, Issue 20
