[Ovmsdev] Easter egg
Mon Apr 9 18:00:14 HKT 2012
I managed to do some more logging in the car over Easter, and found some nice messages:
ID#100
Charge Timer VDS Feedback
B1=06 (timer/plugin setting and timer confirmation)
B2=1B (timer/plugin setting)
B3=0x01
B4=0x00
B5=0x00/0x01 (0x00=plugin, 0x01=timer)
B6=0x00
B7=0x00
B8=0x00
B2=1A (timer start hour)
B3=0x01
B4=0x00
B5=TimerLSB (see id#102 B1=0x05 for details on this)
B6=TimerMSB (see id#102 B1=0x05 for details on this)
B7=0x00
B8=0x00
and
ID#102
Set timer/plugin
B1=05 (timer/plugin setting and timer confirmation)
B3=0x00
B4=0x00
B6=0x00
B7=0x00
B8=0x00
B3=0x00
B4=0x00
B5=TimerLSB \
B6=TimerMSB | (gmthour*60)-1, with special case midnight gmthour=24
B7=0x00
B8=0x00
N.B. Empirical values for TimerLSB and TimerMSB (a GMT+0800 car in Hong Kong) are:
1439 (0x059F) for midnight GMT, 59 (0x003B) for 1am GMT, up to 1379 (0x0563) for 11pm GMT.
It is a bit nasty because the ID#100 messages only seem to be sent in response (confirmation?) to a ID#102 command, so for a newly power-on module we won't be able to show the current setting unless we set the value first.
This is useful ground-work for the finish-charge-by feature, as it would be nice to just use the car timer.
I also found that on ID#100 B1=0x95 charger status message, a car in "Preparing to charge" "Charge scheduled for XX:XX" state will use B2 state 0x0D (preparing to charge) and a newly discovered B3 sub-state 0x05 (waiting for timed start). This seems to be in addition to the previously discovered 0x02 sub-state, and I have still to see when/why one is used vs the other.
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20120409/c7955222/attachment.html>
